Safely typing algebraic effects
- November 26, 2018
Last year (2017), I was following the MPRI, a research-oriented master programme in Paris. The project for the Functional programming and type systems course (taught by François Pottier, Didier Rémy, Yann Régis-Gianas and Pierre-Évariste Dagand) was to write a compiler for a tiny functional language. I extended that project with algebraic effects and a static type system checking that effects could not be unhandled. Explaining the type system of my implementation is what this post is about.
Introduction to algebraic effects
In programming, we say that an expression performs a side effect when its behaviour can depend on the context where it is executed, or modify that context. The most basic examples of this are accessing and modifying a mutable mutable variable, as well as input and output.
Algebraic effects take this idea one step further, and allow
functions to perform user-defined effects, whose behaviour is given
dynamically by an effect handler. Effect handlers control the behaviour
to give to effects during the evaluation of an expression. The syntax
and semantics are very similar to that of exceptions and the
match with exception syntax. Let us recall how these
work:
match f () with
| x -> g x
| exception Not_found -> 42When evaluating the expression above, f () will be
called. If it returns a value x, then g x will
be called and its result will be the result of the whole
match expression. However, if it raises the exception
Not_found, then the result of the match
expression will be 42, and if it raises another exception,
the whole match construct will raise that same exception.
Note that there is an important difference with
try
let x = f () in
g x
with Not_found -> 42in that exceptions in g x are not handled by the
match example: if it raises Not_found, the
match example will re-raise the exception, while the
try example will return 42.
Algebraic effects are quite similar, although the syntax is slightly
different. The keyword perform is used instead of
raise, and effect instead of
exception, with a couple differences. The following
expression
match ... with
| x -> x
| effect Get k -> k 6is a handler around the scrutinee computation .... If
evaluating the scrutinee returns a value x, it is passed by
the handler unchanged. If it raises the Get effect, then
the behaviour is determined by the way the effect Get
clause handles its “continuation” k: the value passed to
k in this clause (here 6) is used to continue the
computation of the scrutinee, starting over where perform
was interrupted (effect handlers generalize Lisp’s “resumable
exceptions”).
With a full example, we have:
let f () = (perform Get) * 7 in
match f () with
| x -> x
| effect Get k -> k 6Here the scrutinee is perform Get * 7, so the
computation restarts as 6 * 7, and the whole
match expression returns 42.
We will not dwell on the uses of algebraic effects here, as our goal, typing effects, only requires to know what the basics of effects are. If you are interested in them, you can learn more here or here.
One problem happening with effects is the same that happens with exceptions: not handling an effect or an exception is an error and interrupts the program. However, it is much more important in the case of effects than exceptions, as effect handlers, unlike exceptions, are not used only in exceptional situations, so there are a lot more places where there is a risk of an error. The whole point of typing being to avoid statically-identifiable errors, we want a type system that prevents them from happening in the first place.
Typing with effects
When we want to type effects, we have to make a difference between
values, which have a type, and computations, which have a type and can
produce effects when executed. We usually write a typing judgement
e : t!Δ when e is an expression of type
t which produces an effect Δ when executed.
However, if we execute let x = e;; in the toplevel, then
the answer will be of the form val x : t, since the value
of x has the type t, and the effect
Δ has already happened, and no longer exists in the
type.
Moreover, since functions perform computations, there is an effect in
the type of the function itself. Thus, an arrow type takes a type and
produces a type with effect. We write s -> (t!Δ) as
s -[Δ]-> t with the effect on the arrow to make it
explicit that it is the function that performs the effect.
Note that a function of type s -[Δ]-> t may perform
the effects in Δ, but it does not have to. However, it may
not perform any effect not listed in Δ.
Another thing to note is that effects can already be expressed in
existing languages using monads, where the type t!Δ woould
be replaced by a value of type M Δ t, where M
is a monad expressing computation. However, making effects first-class
both expresses that effects only happen at computation time and do not
impact the behaviour of an expression after that, and allows easier
design and experimentation about the type system.
First try: row polymorphism and the usual unification algorithm
The first idea for typing effects is to use Hindley-Milner typing. To
capture the fact that a function of type s -[Δ]-> t is
also of type s -[Δ']-> t when Δ is included
in Δ', we use row polymorphism. The type of the function
would now be s -[Δ; !r]-> t with !r a row
variable, that is a variable that quantifies over what can be added to
Δ. That type can later be instantiated to any
s -[Δ']-> t with Δ included in
Δ' by taking !r as the difference of
Δ' and Δ.
For instance, we could define function composition:
let compose f g x = f (g x);;
val compose : ('b -[!r]-> 'c) -[!s]-> ('a -[!r]-> 'b) -[!t]-> 'a -[!r]-> 'c = <fun>The compose function takes two functions as arguments,
and returns their composition. It assumes both input functions can only
produce the effect !r, and the function it returns can then
only produce that effect !r. The two extra effect
variables, !s and !t, are used to make the
function type more general, since we want to use the partial
applications, which will produce no effect at all, in a context where
any function is expected.
However, doing so suffers from over-unification. Indeed, consider the following program for which we wish to infer types using effects:
let rec iter n f x = if n = 0 then x else iter (n - 1) f (f x);;
let double = iter 2;;We would like to get the following type annotations:
val iter : int -[!r]-> ('a -[!s]-> 'a) -[!t]-> 'a -[!s]-> 'a = <fun>
val double : ('a -[!r]-> 'a) -[!s]-> 'a -[!r]-> 'a = <fun>Note that we have row variables everywhere, as usual with row
polymorphism. This is because we want to be able to use a function that
does not perform any effect in any place where a function that performs
an effect is expected. So, while giving double the type
('a -[!r]-> 'a) -[]-> ('a -[!r]-> 'a)
would be correct, it would not allow us to use the function
double f (where f is any function), in a place
where a function performing an effect is expected.
However, with the usual Hindley-Milner type inference algorithm, we get something less general:
val iter : int -[!r]-> ('a -[!r]-> 'a) -[!r]-> 'a -[!r]-> 'a = <fun>
val double : ('a -[]-> 'a) -[]-> 'a -[]-> 'a = <fun>Here, double can only take a function that performs no
effect at all.
So, what happened? If we look in the definition of iter,
the recursive call is done with a type:
int -[!s]-> ('a -[!s]-> 'a) -[!s]-> 'a -[!s]-> 'a
This type is not the same as
int -[!r]-> ('a -[!s]-> 'a) -[!t]-> 'a -[!s]-> 'a,
but only an instantiation of the former. Since this is a
recursive function, the types must be exactly the same, resulting in
!r and !t being unified with !s.
Then, when creating double, the resulting effect of the
evaluation is unified with the empty effect, since top-level statements
are forbidden to produce an effect (remember, we want checked effects),
which prevents double from using a function that performs
an effect.
The problem in the definition of iter is exactly the
same that happens when we write the following in vanilla OCaml:
let rec f x y = f x x;;
val f : 'a -> 'a -> 'b = <fun>Here, a resulting type of 'a -> 'b -> 'c would be
sound as well, but requires polymorphic recursion. It is possible to do
that in the OCaml type system, but requires an explicit annotation. We
do not want that for effects, as it would require to annotate every
single recursive function with its type to get the types we would
like. Although polymorphic recursion making Hindley-Milner type
inference undecidable is a folklore result, it might not be the case if
limited to effect variables as we are trying to do. The existence of the
solution presented below, even if it is based on a different type
system, could be seen as a hint that it might actually remain decidable,
but I did not explore this idea further.
Exploiting subtyping
We need to exploit the structure that exists in the problem at hand to be able to get general enough types. One property we have is subtyping: a function that performs no effect at all can be used where a function that can perform an effect is expected.
In a system with effect subtyping, we expect the following types for the two functions above:
val iter : int -[]-> ('a -[!r]-> 'a) -[]-> 'a -[!r]-> 'a = <fun>
val double : ('a -[!r]-> 'a) -[]-> 'a -[!r]-> 'a = <fun>Here, the recursive call in iter is allowed, since
is a subtype of
int -[!r]-> ('a -[!r]-> 'a) -[!r]-> 'a -[!r]-> 'a,
and thus can be used in its place. double has the expected
type, since the effect type variable !r did not get
unified.
The advantage of using subtyping here is that we did not require polymorphic recursion, that the usual ML type inference algorithm was not able to handle. Unfortunately, by doing so, it seems like we went out of the frying pan and into the fire: we no longer need polymorphic recursion, but we need to handle subtyping instead. Fortunately, a solution exists, which is the recent MLsub inference algorithm by Stephen Dolan, which infers compact (constraint-less) principal types for programs using subtyping.
MLsub is easy to extend to support additional features, in our case
checking effects. We only need to define how effects are typed. Let us
first see a quick summary of MLsub’s features. MLsub extends types with
type union a | b and intersection a & b,
as well as neutral elements, bottom and top,
for these operations. Subtyping in MLsub is structural and not based on
quantification: if a type a is a subtype of b,
then every value of type a is a value of type
b, but the other direction is wrong. This means that to
prove that a type a is a subtype of type b,
only logical operations such as commutativity and associativity of
& and |, or their basic properties can be
used. For instance, int & string would not be a subtype
of bottom, even if it is a logically empty type, because
proving it would require proving that either int or
string are subtypes of bottom, both of which
are false. Moreover, variables as really treated as indeterminates and
not as quantification, for purposes of subtyping. MLsub also has
recursive types, which are needed to assign a principal type to some
expressions like let rec f x = f. Finally, in order to make
type inference decidable, MLsub makes a difference between positive and
negative positions and variable occurrences: during type inference,
| and bottom may only appear in positive
positions, while & and top may only appear
in negative positions. As a consequence, user-definable types must not
include |, &, bottom or
top, since they can be used in both positive and negative
positions.
We will not get into the details of how MLsub’s inference algorithm
works here. Instead, we will see how effects, that we add to MLsub, are
typed. We use a multi-kinded type system, with two kinds: types and
effect types. An effect type corresponds to whether a specific effect
can be present or not: it can either be absent or
maybe present.
Then, as with the other types, we extend this type system to add
|, &, and type variables. Both
top and bottom are added as well, but are
redundant: top is the same as maybe present,
and bottom as absent, except that
absent and maybe present can be used in both
positive and negative positions. Then, when an expression is typed, we
use a single effect type for each effect that appears in the expression,
and a catchall effect type for all other effects, which will all behave
in the same way for that expression, since they do not appear in it. In
other words:
| Arrow type | Desugared | Can perform… |
-[catchall: absent]-> |
no effect at all |
-[A, B]-> |
-[A: maybe present, B: maybe present, catchall: absent]-> |
the effects A and
B |
-[C, !r]-> |
-[C: maybe present, catchall: !r]-> |
the effect C or an effect in
!r |
This is actually the same thing that we had for row polymorphism,
except that with subtyping, row variables are not as omnipresent as
previously: subtyping allows us to use _ -[]-> _ for a
function that does not perform any effect, whereas with only row
polymorphism, we would have needed to use _ -[!r]-> _ to
be able to use this function in a context expecting a function that
produces an effect.
Integrating that in the MLsub inference algorithm gives us precisely what we previously wanted, that is:
val double : ('a -[!r]-> 'a) -[]-> 'a -[!r]-> 'a = <fun>Implementation and conclusion
I implemented MLsub’s type inference algorithm for that project. Although MLsub’s paper explained quite well the ideas behind MLsub to give a good enough intuition about it, I needed to read Stephen Dolan’s thesis to be able to implement it. Besides, I managed to get a simple implementation only after reading his code and realizing that a structural type with destructive unification can be used to implicitely represent the automaton with references, making the implementation of the algorithm a lot closer to that of Hindley-Milner type inference with destructive unification, and thus a lot simpler. With that representation in mind, all algorithms become a lot more natural to write and easier to understand, at least for someone which has already some experience with Hindley-Milner type inference. All in all, the typer, which only supports a very simple type system if you exclude effects and subtyping, is about 1500 lines long and requires quite complicated types in some places (one of them is a type where some constructors contain sets of elements of the type itself, requiring the use of recursive modules).
There still are some rough edges, though. First and foremost, effects cannot hold type information. This means that polymorphic effects are completely impossible. Second, it is unclear how to treat local effects (similar to local exceptions in OCaml): how can it be guaranteed that a function that raises a given local effect can never escape the scope where that local effect is defined?
The first of these problems is mainly due to the semantics of effect matching. In the case of nested effect handlers for the same effect, performing the effect inside the innermost handler causes that handler to be used. However, in some cases, that use of the effect will have been typed with respect to the outermost handler. With pre-defined effects that have a fixed type, this causes no problem. However, with polymorphic effects, they might correspond to different instantiations, breaking type safety. For instance, consider the functions below:
let g f = match f () with x -> x | effect Exit _k y -> y;;
let () =
match g (fun () -> perform (Exit false); 6) < 7 with
| x -> x
| effect Exit _k y -> yNow, g is well-typed with type
(unit -[Exit : 'a, !r]-> 'a) -[!r]-> 'a
which is a subtype of
(unit -[!r]-> 'a) -[!r]-> 'a
Instanciating it with !r = Exit : bool and
'a = int makes the whole expression well-typed, when it
tests if false < 7 at runtime, breaking type safety.
A way to prevent that which would not be overly restrictive in terms
of expressivity would be to disallow such cases in the type system, and
add protect and unprotect operators that would
hide the effect of a subexpression from the surrounding effect handler.
They could even be added in a type-directed way, but the semantics of
the language will depend on the typing.
Concerning the second problem with local effects, a straightforward check is to ensure the added effect does not leak into the return type of the function. However, I have no proof that it is correct for now, so if you have one or find a counter-example, please leave a comment about it.
In case you want to learn more about MLsub, I encourage you to read Stephen Dolan’s MLsub paper, or even his whole thesis. If you are interested in joujou’s typing rules, you can have a look at them in the report for the project (in French).
