From visitors to iterators
- March 14, 2017
I have been asked whether an automatically-generated visitor, as produced by the visitors syntax extension for OCaml, can be used to construct an iterator.
It turns out that this can be done in a simple and efficient manner. (Up to a constant factor, the time complexity of this solution is optimal.) As the problem is interesting and its solution is somewhat nonobvious, I am describing them here.
To play with this code in an OCaml toplevel, first install
visitors via the command
opam install visitors. Then, launch ocaml and
type this:
#use "topfind";;
#require "visitors.ppx";;
#require "visitors.runtime";;
Problem Statement
Suppose we have an arbitrary data structure that contains elements of
type 'a. Here, it is a binary tree, but it could be
anything:
type 'a sometree =
| Leaf
| Node of 'a sometree * 'a * 'a sometreeWe would like to enumerate the elements of this data structure. More precisely, we would like to construct an iterator, that is, an on-demand producer of elements. Here is a simple definition of a stateful iterator:
type 'a iterator =
unit -> 'a optionThe question is, can we construct an iterator for the type
'a sometree, based on an automatically-generated visitor,
so that the construction is entirely independent of the type
'a sometree?
Cascades
For starters, let us define cascades, which are a more pleasant kind of iterators. A cascade is a persistent (stateless) iterator. It can be thought of as a delayed list, that is, a list whose elements are computed only on demand.
Cascades could (should) be part of a separate library. As the time of writing (March, 2017), there is in fact a proposal to add them to OCaml’s standard library.
type 'a cascade =
unit -> 'a head
and 'a head =
| Nil
| Cons of 'a * 'a cascadeA delayed computation is represented as a function of type
unit -> _.
The cascade constructors are as follows:
let nil : 'a cascade =
fun () -> Nil
let cons (x : 'a) (xs : 'a cascade) : 'a cascade =
fun () -> Cons (x, xs)Forcing a cascade reveals its head:
let force xs =
xs()A cascade can be easily converted to a stateful iterator:
let cascade_to_iterator (xs : 'a cascade) : 'a iterator =
let s = ref xs in
fun () ->
match force !s with
| Nil ->
s := nil;
None
| Cons (x, xs) ->
s := xs;
Some xIn the above code, writing nil into s may
seem superfluous, but is in fact necessary to guarantee that the
computation that led to a Nil outcome is not repeated in
the future.
Because cascades are close cousins of lists, they are easy to work with. Constructing a cascade for a tree-like data structure is straightforward, whereas directly constructing a stateful iterator would be more involved.
Back to the problem
Now, can we use some kind of visitor to turn a tree of type
'a sometree into a cascade of type
'a cascade?
At first sight, this does not seem very easy, because of two issues:
a visitor usually traverses a tree in an eager manner, whereas we need the traversal to make progress only as cascade elements are demanded;
a visitor performs a bottom-up computation, without a left-to-right bias (assuming mutable state is not used), whereas a cascade enumerates elements in a left-to-right manner. (Or in a right-to-left manner. As will be apparent below, both directions are possible.)
The trick is to use another intermediate step. Instead of turning a
tree directly into a cascade, we first transform it into a generic
tree-like structure: a delayed tree. The first issue above is
solved because, by introducing delays into the new tree, we allow its
construction to be carried out on demand. The second issue is solved
because this tree-to-tree transformation can be carried out in a purely
bottom-up manner by a reduce visitor. Then, finally, it is
straightforward to transform a delayed tree into a cascade.
From Delayed Trees to Cascades and Iterators
A delayed tree contains ordinary nodes of arity 0, 1, and 2.
Furthermore, it contains DTDelay nodes, of arity 1, whose
child is delayed, that is, computed only on demand.
type 'a delayed_tree =
| DTZero
| DTOne of 'a
| DTTwo of 'a delayed_tree * 'a delayed_tree
| DTDelay of (unit -> 'a delayed_tree)A delayed tree is converted to a cascade as follows. As is often the
case, when building a cascade, one must take a continuation
k as an argument, so as to avoid naive and costly cascade
concatenation operations. Thus, the specification of the function call
delayed_tree_to_cascade dt k is to construct a cascade
whose elements are the elements of the delayed tree dt
(listed from left to right), followed with the elements of the cascade
k.
let rec delayed_tree_to_cascade (dt : 'a delayed_tree) (k : 'a cascade)
: 'a cascade =
fun () -> delayed_tree_to_head dt k
and delayed_tree_to_head (dt : 'a delayed_tree) (k : 'a cascade) : 'a head =
match dt with
| DTZero ->
force k
| DTOne x ->
Cons (x, k)
| DTTwo (dt1, dt2) ->
delayed_tree_to_head dt1 (delayed_tree_to_cascade dt2 k)
| DTDelay dt ->
delayed_tree_to_head (force dt) k
let delayed_tree_to_cascade (dt : 'a delayed_tree) : 'a cascade =
delayed_tree_to_cascade dt nil
let delayed_tree_to_iterator (dt : 'a delayed_tree) : 'a iterator =
cascade_to_iterator (delayed_tree_to_cascade dt)In the above code, we have chosen to perform a left-to-right traversal of the delayed tree, but could just as well have chosen a right-to-left traversal.
It is possible to make the delayed tree data structure implicit in the code; this is explained further on.
Constructing Delayed Trees
The type 'a delay is a synonym for 'a. We
will use it as a decoration, in a type definition, to indicate that a
call to the method visit_delay is desired.
type 'a delay = 'aWe now set up four constructor functions or constructor methods,
which construct delayed trees, and which we will use in a
reduce visitor.
Delayed trees form a monoid, in the sense that we concatenate them
using DTTwo, and the neutral element is
DTZero. We package these two data constructors in the
methods zero and plus, which are automatically
called in an automatically-generated reduce visitor.
The visitor method visit_delay delays the visit of a
subtree by constructing and returning a DTDelay node, which
carries a delayed recursive call to a visitor.
The visitor function yield will be invoked at elements
of type 'a. It constructs a one-element delayed tree.
class ['self] delayed_tree_monoid = object (_ : 'self)
method zero =
DTZero
method plus s1 s2 =
match s1, s2 with
| DTZero, s
| s, DTZero ->
s
| _, _ ->
DTTwo (s1, s2)
method visit_delay: 'env 'a .
('env -> 'a -> 'b delayed_tree) ->
'env -> 'a delay -> 'b delayed_tree
= fun visit_'a env x ->
DTDelay (fun () -> visit_'a env x)
end
let yield _env x =
DTOne xIn the method plus, above, treating DTZero
specially is not mandatory. It is an optimization, which helps allocate
fewer nodes.
Generating a Visitor
It is now time to generate a reduce visitor for the type
'a sometree. This is the only part of the code which is
specific of sometree. Everything else is generic.
We must insert delays into the structure of the type
'a sometree so as to indicate where
visit_delay should be called and (therefore) where
DTDelay nodes should be allocated. To do this, we write a
copy of the definition of the type 'a sometree, with extra
uses of delay in it. The new type is actually considered
equal to 'a sometree by OCaml. Its role is purely to carry
a @@deriving visitors annotation.
In the data constructor Node, the left-hand
delay is in fact superfluous. With or without it, our
iterators will eagerly descend along the leftmost branch of a tree,
anyway.
type 'a mytree = 'a sometree =
| Leaf
| Node of 'a mytree delay * 'a * 'a mytree delay
and 'a mytree_delay =
'a mytree delay
[@@deriving visitors { variety = "reduce"; polymorphic = true;
concrete = true; ancestors = ["delayed_tree_monoid"] }]This approach is pleasant insofar as one controls exactly where delays are inserted. However, it requires copying the type definition, which may be unpleasant. Another approach is described further on.
Using the Generated Visitor
For demonstration purposes, let us make our visitor verbose. In
production, one should remove verbose_reduce and use
reduce instead.
class ['self] verbose_reduce = object (_ : 'self)
inherit [_] reduce as super
method! visit_Leaf visit_'a env =
Printf.printf "Visiting a leaf.\n%!";
super#visit_Leaf visit_'a env
method! visit_Node visit_'a env t1 x t2 =
Printf.printf "Visiting a node.\n%!";
super#visit_Node visit_'a env t1 x t2
endThe problem is solved! There remains to write a couple lines of glue code:
let sometree_to_delayed_tree (t : 'a sometree) =
new verbose_reduce # visit_mytree_delay yield () t
let sometree_to_iterator (t : 'a sometree) : 'a iterator =
delayed_tree_to_iterator (sometree_to_delayed_tree t)We use visit_mytree_delay above, even though
visit_mytree would work just as well, so as to ensure that
we get a delayed tree whose root is a DTDelay node. Thus,
absolutely no work is performed when the iterator is created; iteration
begins only when the first element is demanded.
Demo
A little demo helps see what is going on.
let t : int sometree =
Node (Node (Leaf, 1, Leaf), 2, Node (Leaf, 3, Leaf))
let i : int iterator =
sometree_to_iterator tHere is a transcript of an OCaml toplevel session:
# i();;
Visiting a node.
Visiting a node.
Visiting a leaf.
- : int option = Some 1
# i();;
Visiting a leaf.
- : int option = Some 2
# i();;
Visiting a node.
Visiting a leaf.
- : int option = Some 3
# i();;
Visiting a leaf.
- : int option = None
# i();;
Variant: Avoiding Duplication of the Type Definition
Earlier, we have generated a visitor for the existing type
'a sometree in a posteriori style. We have
manually created an isomorphic copy of the type
'a sometree, which we have named 'a mytree,
and have annotated this copy with
[@@deriving visitors { ... }]. Furthermore, we have taken
this opportunity to insert delay type constructors into the
type, so as to influence the generated visitor.
This style is relatively pleasant because it is declarative and lets
us control exactly where delays are inserted. However, it requires
duplicating the definition of the type 'a sometree, which
may be unpleasant (if the definition is large) or impossible (if the
definition is hidden behind an abstraction barrier).
Another approach is to generate a visitor in a priori style.
When the type 'a sometree is first defined, a
reduce visitor can be immediately generated for it, as
follows:
type 'a sometree =
| Leaf
name = "sometree_reduce" }]At this point, we pretend that we do not know yet what this visitor
will be used for, so we do not annotate the type definition with
delay, and do not use delayed_tree_monoid as a
base class. We get a visitor class, named sometree_reduce.
This class has two virtual methods, zero and
plus.
Then, we create a subclass, named reduce, which we
tailor to our needs. We mix the generated class
sometree_reduce with the class
delayed_tree_monoid, and insert a delay at every tree node
by overriding the method visit_sometree:
class ['self] reduce = object (self : 'self)
inherit [_] sometree_reduce as super
inherit [_] delayed_tree_monoid
method! visit_sometree visit_'a env t =
self#visit_delay (super#visit_sometree visit_'a) env t
endThe rest of the code is unchanged (except the method
visit_mytree_delay no longer exists; one calls
visit_sometree instead).
Variant: Getting Rid of Explicit Delayed Trees
I like to present delayed trees as an explicit data structure, because this helps understand what is going on. However, if desired, it is possible to hide them by refunctionalization (the opposite of defunctionalization).
Above, the function delayed_tree_to_cascade was written
with the help of an auxiliary function,
delayed_tree_to_head. We could also have written it
directly, as follows:
: 'a cascade =
match dt with
| DTZero ->
k
| DTOne x ->
cons x k
| DTTwo (dt1, dt2) ->
delayed_tree_to_cascade dt1 (delayed_tree_to_cascade dt2 k)
| DTDelay dt ->
fun () -> delayed_tree_to_cascade (force dt) k ()In this form, the only function that is ever applied to a delayed
tree is delayed_tree_to_cascade. Therefore, wherever we
construct a delayed tree t, we could instead directly build
a closure whose behavior is equivalent to
delayed_tree_to_cascade t. This is
refunctionalization.
The data structure of delayed trees seems to disappears. The type
'a delayed_tree can be defined as a synonym for a
'a cascade -> 'a cascade. I usually refer to this type
as 'a producer: it is the type of a function that
concatenates elements in front of the cascade that it receives as an
argument.
type 'a producer =
'a producerThe four data constructors are defined as follows:
let _DTZero k =
k
let _DTOne x k =
cons x k
let _DTTwo dt1 dt2 k =
dt1 (dt2 k)
let _DTDelay dt k =
fun () -> force dt k ()The reader can check that the types of these data constructors are
the same as in the previous version of the code. For instance,
_DTDelay has type
(unit -> 'a delayed_tree) -> 'a delayed_tree.
The root function delayed_tree_to_cascade (without a
continuation argument) is defined as follows:
dt nilThe delayed tree monoid uses the new versions of the four data constructors:
method zero =
_DTZero
method plus =
_DTTwo
_DTDelay (fun () -> visit_'a env x)
end
let yield _env x =
_DTOne xThe four functions _DTZero, _DTOne,
_DTTwo, and _DTDelay could be inlined, if
desired, so as to make the above code seem even more concise.
The rest of the code is unchanged.
Acknowledgements
KC Sivaramakrishnan asked whether a visitor can be used to construct an iterator. Gabriel Scherer pointed out that the delayed tree data structure can be hidden by refunctionalization.
