A toy type language (2) variance 101
- January 17, 2014
- Last updated on 2014/01/17
In this second installment of the “toy type language” series, we will explain how to compute the variance of mutually recursive parameterized types. The actual implementation will be the topic of a following post.
The interest of variance is best seen in combination with a subtyping
relation. We therefore assume a type system equipped with a subtyping
relation which we write as ≤. In order to give meaningful
examples of subtyping, I will use polymorphic variants, so that
readers familiar with that feature of OCaml can follow the discussion
easily.
The type of values that may only be the constructor A,
which OCaml can express as [ `A ], is a subtype of the type
made up of two constructors A and B, written
[ `A | `B ]. We write this as
[ `A ] ≤ [ `A | `B ]: any inhabitant of the smaller type
can be seen as an inhabitant of the bigger type. One can think in terms
of sets, in which case ≤ is the set inclusion relation
Variance is a property of a parameterized type with regards to one of
its parameters. If t a is a parameterized type, the
variance of t with regards to a will give us
information about the kind of subtyping relation that two types
t a and t b enjoy, depending on the subtyping
relation between a and b.
Variance is especially important for abstract types. The definition of an abstract type is hidden; therefore, unless otherwise specified, no subtyping relations are available. However, we may want to reveal in a module’s signature that a type has a certain variance, so that the type-checker be aware of certain subtyping relations. Therefore, variance is a property that we will sometimes want to export through a module signature.
The four possible variances
Covariance
type 'a list =
| Nil
| Cons of 'a * 'a listIf we see list as a function from types to types, then
list is nondecreasing: assuming a ≤ b, we have
list a ≤ list b1. We say that
list is covariant in its first parameter.
If the type list were to be abstract, revealing that it is
a covariant type would make sure the type-checker is aware that
“a ≤ b ⇒ list a ≤ list b”.
Contravariance
type 'a printer = 'a -> unitWe now turn to the printer type, which is that of a
function that can print elements of type 'a. Intuitively,
if a function can print elements with constructor A or
B, it can also print elements with only constructors
A: the function’s B case will just never be
called. In other words, we can see a printer [ `A | `B ] as
a printer [ `A ], which we write
printer [ `A | `B ] ≤ printer [ `A ]. This fact is true
even though [ `A ] ≤ [ `A | `B ]. This is the opposite of
list: printer is a nonincreasing function from
types to types. We say that printer is
contravariant in its first parameter.
Invariance
type 'a list_with_printer = 'a printer * 'a listHere, the list_with_printer type is made up of a
covariant type and a contravariant type; list_with_printer
is neither co- nor contravariant. We say that it is
invariant, meaning the list_with_printer
does not enjoy any subtyping relation. This is the default variance: an
abstract type is considered to be invariant by default.
Bivariant
type 'a t_bi = ()A rarely useful variance is bivariance, when a type
is both co- and contravariant. This is only possible if
the type does not use its type parameter, such as t_bi in
the example above. Indeed, we always have both
t_bi a ≤ t_bi b and
t_bi b ≤ t_bi a for any a and
b.
OCaml notation
We now need to reveal the variance of an abstract type through a module signature, so that the type-checker can take advantage of this extra information. OCaml offers notation in module signatures for all variances, except bivariance.
module M: sig
type +'a co_t
type -'a contra_t
type 'a inv_t
end = struct
type 'a co_t = 'a list
type 'a contra_t = 'a printer
type 'a inv_t = 'a printer * 'a list
endThe variance lattice
Variance forms a complete lattice, which induces a “meet” (“goes
down”) and a “join” (“goes up”) operation, which we respectively write
as ∩ and ∪.
inv
co contra
bi
Computing variance
We now turn to the actual process of computing variance. Let’s assume first that a recursive procedure is enough to compute the variance of a given data type.
First example
Consider the list_with_printer type. When trying to
compute variance(list_with_printer, a), we need to compute
variance(list, a) and variance(printer, a).
Assuming the variances for list and printer
have been computed already, we obtain co and
contra. Then, the variance of
list_with_printer is one that subsumes both the
variance of list and printer, as the two
appear in the definition of list_with_printer. Finding a
variance that is greater than both co and
contra corresponds to a “join” operation on the
lattice.
In short,
variance(list_with_printer, a) = variance(list, a) ∪ variance(printer, a)
= co ∪ contra
= inv
Recursion
For the example above, a simple recursive computation may suffice.
However, in the presence of recursion, computing the variance of
list requires that one knows the variance of
list already, as list occurs in its own
definition!
The variance for list can be computed using a
least fixed point: we initially assume the variance of
list to be the “best” possible (bivariant). Under this
hypothesis, we compute the variance of list, which turns
out to be co.
We then perform a second iteration: assuming list is now
covariant, the computed variance for list is still
co: we have reached a fixed point.
Starting from the bottom of the lattice guarantees we reach the
least fixed point: indeed, invariant is a valid fixed
point for list, but not the best (least) one.
We can sum up this procedure as follows, where the fixed point is not reached until the second line.
variance(list, a): bi ⊢ variance (list, a) = co
variance(list, a): co ⊢ variance (list, a) = co
Systems of equations
We can express variance using a system of equations. Back to the
list_with_printer example, if v is the
variance associated to the parameter a of
list_with_printer, we write:
v = variance(list_with_printer, a)
How do we compute the variance? We look up the definition of
list_with_printer, and figure out that this type is defined
to be a tuple. Computing variance for a tuple is easy; we just apply the
“join” operation.
(* [variance t a] computes the variance of parameter [a] in type [t] *)
variance :: type -> parameter -> variance
variance((t, u), a) = variance (t, a) ∪ variance (u, a)This reduces to:
v = co ∪ contra
Solving this equation is straightforward and the fixed-point
computation is trivial: inv is the least fixed point of
that equation, therefore, list_with_printer is invariant
over its first parameter.
Negation
We have shown the definition of the variance function in
the case of tuples. Another easy case is that of a variable:
variance(a, a) = co
variance(b, a) = bi
The variance of a in a itself is covariant;
the variance of a in another, distinct type variable is
bi, as a does not appear in type
b.
Arrow types are __contra__variant in their domain: if a
appears in covariant position in t, a is
__contra__variant in t -> unit. We therefore introduce a
negation operator, which we write -, defined as
follows:
-inv = inv
-co = contra
-contra = co
-bi = bi
variance(t -> u, a) = - variance(t, a) ∪ variance (u, a)
Composition
We still haven’t defined the variance function in the
case of type applications, which we write t u. Computing
the variance of a in t u requires
composing the variance of t in its first
parameter and the variance of a in u.
Still seeing data types as functions, this amounts to computing the monotonicity of the composition of two functions.
If v is the variance of t in its first
parameter, and w is the variance of a in
u, then we define variance as follows:
variance(t u, a) = var_for_param(t, 0) . variance(u, a)
We compose the variance of t in its
first parameter with the variance of a in
u.
How should we define the dot operator? Let us take some examples. If
variance(u, a) = w, then variance(list u, a)
remains w: we say that co.w = w. Conversely,
variance(printer u, a) is -w: we have
contra.w = -w. An interesting case if that of bivariance:
if a does not appear in u, then a
won’t appear in t u, meaning v.bi = bi.
Symmetrically, if t does not use its parameter
u, then a won’t appear in t u,
meaning bi.w = bi. Finally, composing an invariant type
with any other type yields an invariant type.
The composition of v and w, which we write
as v.w, is summed up in the following table.
v.w |
inv | co | contra | bi | w |
| inv | inv | inv | inv | bi | |
| co | inv | co | contra | bi | |
| contra | inv | contra | co | bi | |
| bi | bi | bi | bi | bi | |
v |
This allows us to write the system of equations for the
list type:
v = (co ∪ v.co) ∪ bi
Mutually recursive data types
The fixed-point computation becomes much more interesting in the case of multiple, mutually recursive data types. Consider the following definition:
type ('a, 'b) t =
| Foo of ('a -> 'b)
| Bar of ('a * 'b, 'b) u
and ('c, 'd) u =
| Baz of ('c, 'c) tThe system of equations needs four variables, va,
vb, vc and vd which are the
variances of all four type parameters.
va = -co ∪ bi ∪ vc.co ∪ vd.bi
vb = -bi ∪ co ∪ vc.co ∪ vd.co
vc = va.co ∪ vb.co
vd = va.bi ∪ vb.bi
We have now explained how to write down the recursive equations that
allow one to compute the variance of mutually recursive data types. The
next and final blog post will show how to compute the least fixed point
for any set of equations, using the Fix library.
