My picture
Gabriel Scherer
I do programming and research into programming languages.
Until 2015 I was a PhD student in the Gallium team (see our shared research blog!) at INRIA Paris-Rocquencourt, France. My advisor is Didier Rémy.
Since 2016, I am a post-doc at the Programming Research Laboratory at Northeastern University, Boston, working with Amal Ahmed on fully abstract compilation and multi-language semantics.
My main interest is programming languages. I'm familiar with statically typed functional programming languages such as OCaml, or more generally of ML tradition (SML, Haskell...). I'm interested in theoretical aspects of type systems, programming language implementation, general programming language concepts, and even some syntactic aspects. I have a preference for the formalizable aspects, or formalizable approaches to programming language aspects, rather than the often subjective appeal to taste or intuition.
(CV)
Contact information
Outside the personal sphere, I communicate by e-mail -- and interleaved forum, mailing-list or blog posts. Please feel free to send me an email; I mostly use my Gmail adress, gabriel dot scherer at gmail.
Research themes and documents
Types having a unique inhabitant
I'm currently working on the question of knowing whether a given type T has a unique inhabitant -- modulo a given notion of program equivalence. I wrote two blog posts (part 1, and part 2) on the idea. I gave a talk in may 2013 at the PLUME seminar in Lyon, whose slides are available. I discussed some examples applications at the Dependently Typed Programming (DTP'13) Workshop (abstract, slides)
In early 2015 I proposed an algorithm to decide unique inhabitation in the simply-lambda calculus with sums, modulo beta-eta-equivalence. A draft and a prototype implementation are available there.
My thesis, defended in March 2016, expands on this. See the specific phd page or the manuscript. Abstract:
Some programming language features (coercions, type-classes, implicits) rely on inferring a part of the code that is determined by its usage context. In order to better understand the theoretical underpinnings of this mechanism, we ask: when is it the case that there is a unique program that could have been guessed, or in other words that all possible guesses result in equivalent program fragments? Which types have a unique inhabitant?
To approach the question of unicity, we build on work in proof theory on more canonical representation of proofs. Using the proofs-as-programs correspondence, we can adapt the logical technique of focusing to obtain more canonical program representations.
In the setting of simply-typed lambda-calculus with sums and the empty type, equipped with the strong beta-eta-equivalence, we show that uniqueness is decidable. We present a saturating focused logic that introduces irreducible cuts on positive types “as soon as possible”. Goal-directed proof search in this logic gives an effective algorithm that returns either zero, one or two distinct inhabitants for any given type.
Eta-equivalence with sums
To start the research on unique inhabitants, I have been looking at the work on ((maximal) (multi-)focusing for type/proof systems with sum types. (See these 2014 slides introducing maximal multi-focusing.)
There are interesting connections between these proof-theoretical techniques and the problem of deciding equivalence of pure program. I have looked at these connections from two different angles:
Full reduction in the face of absurdity
When designing type systems for programming languages, there is often an unnoticed mismatch between the dynamic semantics we use and the soundness guarantees given by the type system. We use weak reduction strategies (for implementation reasons or to reason about side-effect order) but type-soundness would actually hold ("Well-typed program do not go wrong") if we used full reduction, allowing to reduce under lambdas.
This is all fine, until we end up designing language feature that break the latter property (safety with respect to full reduction), and we don't notice because we only play with the weak reduction. It means there is something fundamental about those features that we haven't noticed/understood, that should be important for reasoning about programs. GADTs are such a feature.
Didier and I study this question in the following draft: Full reduction in the face of absurdity (2014). To technically support our consideration, this document uses a consistent coercion calculus as developped by Julien Crétin during his PhD thesis -- it is a very convenient and expressive framework in which to study these issues. For a simplified setting (System F plus logical assumptions), you may want to look at my slides (with notes) from the Journées LTP du GDR GPL, October 2014.
Theoretical aspects of mixing GADTs and subtyping in OCaml
When GADTs were added by Jacques Garrigue and Jacques Le Normand in OCaml 4.00, we found out that their interaction with subtyping had not been studied theoretically, in particular we were not sure how to soundly assign variances to GADT parameters, and a very restrictive criterion was implement in OCaml. I worked in 2012 on finding the right variance check for GADTs, and this resulted in the article GADTs meet subtyping (arxiv), also available as a long version or slides.
Meta-theory of predicative dependent type theories, using logical relations
In 2011, I worked with Andreas Abel on meta-theoretical aspects of predicative dependent type theories -- definitional-algorithmic correspondence with logical relations, and universe subtyping and polymorphism. I enjoyed collaborating to his article On Irrelevance and Algorithmic Equality in Predicative Type Theory (arxiv), and also wrote a much less rigorous internship report on the question of universe subtyping.
Computational meaning of semantic proofs techniques
I find the effectiveness of logical relations rather perplexing. In recent work (2015) with Pierre-Évariste Dagand, I tried to better understand semantic techniques in a much simpler setting, by studying the computational content of a classical realizability proof on the simply-typed lambda-calculus: Normalization by Realizability also Evaluates.
MLF type inference and type-level computation
In a former internship with Didier Rémy at Gallium (2010), I worked on MLF, an System F-like type system with type inference; I did some prototyping and explored adding Fω-style type-level operators. A horribly-formated report is available, but this topic would need some more work because it raised more questions than it answered.
A type-safe database library using phantom types
In June-July 2009, I worked with Jérôme Vouillon on a statically typed domain-specific language for database queries embedded in OCaml, Macaque. The library is publicly available and in a minimal maintainance mode (if bugs are found, they get fixed). We wrote a french-language article for JFLA'10.
Teaching
Since autumn 2008 I've enjoyed being a teaching-assistant in slightly more than a class a year on average. Some old teaching documents are available there, most of it in French.
